Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1995 Chevy Corsica 6 cyl Front Wheel Drive Manual 135000 miles
I have a small oil leak. I have been told it is either a gasket or val
What kind of repair do I need? How can you determine where it is coming from and what price should I expect to fix this problem?
Hello Carline,
To determin the repair needed, we need to determin were the leak is at.
One way to find the leak would be to clean the engine. Then run for a day or 2 since it is a small leak may take a day or so to show up again. Or just keep checking the engine every so often during the day.
Look for wet areas around the Valve Covers the front of the engine around the big pulley at the bottom. Look all around.
Another way would be to go to your local auto parts store ask for ultraviolet oil dye or oil leak finder. Put it in the oil and drive for a while then using a Black Light look for the Florescent Green Dye.
If not sure name of area were leak is take pic and post here if possible.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
