Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1995 Chevy Cheyenne 6 cyl Two Wheel Drive Automatic 253355 miles
the truck won't start, it makes a click when you try and start it so we took the battery and alternator to autozone and they are ok. put on a new starter but still nothing....the battery cables are getting hot and hot to touch....what is happening.......my husband tried to get the engine to turn over but can't get the bolts off to do it..he thinks the engine is froze up.......PLEASE HELP...........HE HAS TO DRIVE IT TO WORK TOMORROW............
Double check battery connections make sure its cleaned/tightened. Have helper put key at crank position -Look for power at the starter solenoid small purple wire terminal power there-replace the starter. No pwer backtrack it to the transmission range switch and ignition switch.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
