Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair1993 Jeep Cherokee 1993...
Auto Repair1998 Mercury Station Wag...
Auto Repair1990 Honda Accord Compu...
Auto Repair1995 Jeep Laredo Brakes...
Auto Repair1996 Mitsubishi Eclipse ...
Auto Repair2003 Ford Mondeo Car Je...
Auto Repair1996 Nissan 200sx Car H...
Auto Repair More Repair Topics...
Car Repair Advice by Professional Automotive Experts
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1995 Chevy Blazer engine won't start
Posted at Tue Sep 29, 2009 7:25 am
By daiwms, Likes to hang around!
(7) Give Feedback | Votes: 0
Engine Mechanical problem
1995 Chevy Blazer 6 cyl Four Wheel Drive Automatic 150k miles
I have replaced the egr valve, electronic ignition sensor,distributor,rotor magnetic pickup,coil, wires plugs, and this truck won't start. it won't even respond to stating fluid. there is spark from the coil, distrib, and plugs. I tried a tps,and crank sensor I even replaced the computer. it still would'nt start so I put the original cpu back on. I am at wits end. help!!! Oh I also replaced two fuel pumps,and the fuel filter.
Find a car repair manual for your Chevy Blazer Repair Question.
Posted at Mon Oct 19, 2009 7:40 am
By Jacobandnickolas, Certified 2CarPros Master Technician
Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1Reputation: 15819.1 (15819) Give Feedback | Votes: 122
Are you getting power to the coil?
Posted at Mon Oct 19, 2009 9:54 am
the coil has power, as well as the distributor and spark plugs. would a defective distributor prevent fuel from reaching the plugs in a vortech engine? when I turn it over the plugs aren't wet....
Posted at Mon Oct 19, 2009 10:22 am
No, the distributor wouldn't cause the fuel pump not to work. Have you checked fuel pump pressure? Have you checked the fuel pump relay or if the pump to see if it is getting power?
Posted at Wed Oct 28, 2009 9:52 am
fuel pump is new, registers at least 55 psi at strader valve. there is every indication power is surging through the plugs, coil, and distributor. all the fuses work. I assume the relays are functioning because the fuel pressure reg. is allowing the fuel to reach the strader valve. What next? School me plz.
Posted at Wed Oct 28, 2009 10:38 am
If you have spark and fuel, it should run unless there is a timing problem or compression problem. Will the engine start with starting fluid?
Posted at Sat Nov 07, 2009 12:39 pm
no it will not start w/starting fluid. however, I did use a noid light. it indicated that there ws no power to the injectors. what now?
Posted at Sat Nov 07, 2009 8:20 pm
Usually that indicates a bad PCM (computer). However, I recommend checking wiring and connections.
THe odd part about this is you have spark to the plugs and it still won't start.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
