Engine Cooling problem
1995 Chevy Beretta 6 cyl Two Wheel Drive Automatic 144000 miles
There is water/antifreeze pouring from the "rear" of the engine. The place that the water is coming from is a little plastic tube with an eblow shaped rubber boot on it. It looks as if maybe a hose or tube of some kind should be plugged into the boot, although I couldn't find anything that looks like it came out of it. Above this place where the water is coming out, there are a couple of "high pressure"?? hoses (with steel ends) attached. Would this be something for the heater core?
