Car Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
1995 Cadillac STS 1995 Cadillac STS Seville Won't Start, Ba
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Sun May 11, 2008 10:55 pm |
By
zahmin89,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
1995 Cadillac STS V8 Front Wheel Drive Automatic 124000 miles
So far I have replaced the starter which was in pieces and the battery which was dead. I got it to run, but it would backfire sometimes when I started it up and it was idling very rough. I replaced the intake manifold gasket and the o-ring for the intake manifold as well, thinking that an air leak could explain how rough it was running. Since I replaced them, the car will not start. Instead it backfires under the engine or in the engine, I can't tell. I'm thinking it's either a timing problem or an engine valve problem that's causing fuel to get into the intake manifold during startup and causing the backfiring. Am I correct? What do I need to do to get it to start?
| Find a
car repair manual for your Cadillac STS Repair Question. |
Posted at Mon May 12, 2008 6:29 am |
By
Buzzsaw,
Moderator |
          (216) Give Feedback | Votes: 13 |
| rasmataz wrote: | If you're sure there's no false air/vacuum leakage do below changing I/M gasket will not throw off the valve/ ignition timing unless you didn't set the distributor back in correctly-
Do a fuel pressure check with a fuel pressure tester designed for your fuel system to rule out the fuel filter/pressure regulator and fuel pump then come back and give me the pressure readings so I can evaluate the situation and what direction you need to go-this is where we start the diagnosis. |
you need to scan your codes, off and warmer on the heater controls, with the key in the on position
its distributorless so timming isnt affected
| Find a
Posted at Mon May 12, 2008 7:24 am |
By
zahmin89,
Have Donated |
Initially we thought we had a leak in the I/M gasket that was letting fuel under the I/M but we have since figured out that there is a flapper door on the end of the I/M. The flames we have seen are coming out of that. While the car is cranking and trying to start we can hear the little flapper opening and closing. After cranking for a few seconds we get a loud pop that sometimes shoots flame out the intake. I am thinking this can be a timing issue but not certain. I have never seen ignition into the intake before so this is new territory for me. I will read the codes tonight and see what it says. I will have to go get a fuel pressure gauge to check that. Thanks for your help with this I will let you know what I find tonight.
| Find a
Posted at Tue May 13, 2008 6:35 am |
By
zahmin89,
Have Donated |
I read the codes and looked them up last night and everything came up as either a KAM reset or a suspension code. The battery was dead for a long time on this car and i assume that is why everything is reset.
Is it likely this ignition into the I/M can be caused by a vacuum leak? I was looking at the vacuum lines last night and saw a cracked rubber boot that has three lines into the throttle body (working from memory here). I also have one open port coming out of a cannister on the throttle body. I cannot find any disconnected hose however. I will try to find a vacuum schematic and follow it to see what i am missing. Thanks.
| Find a
Posted at Tue May 13, 2008 8:36 am |
By
Buzzsaw,
Moderator |
| zahmin89 wrote: | I read the codes and looked them up last night and everything came up as either a KAM reset or a suspension code. The battery was dead for a long time on this car and i assume that is why everything is reset.
Is it likely this ignition into the I/M can be caused by a vacuum leak? I was looking at the vacuum lines last night and saw a cracked rubber boot that has three lines into the throttle body (working from memory here). I also have one open port coming out of a cannister on the throttle body. I cannot find any disconnected hose however. I will try to find a vacuum schematic and follow it to see what i am missing. Thanks. |
replace your MAP sensor, its on top of the throttle body, its not expensive ( a little rectangular black box )
| Find a
Posted at Thu May 29, 2008 4:25 pm |
By
zahmin89,
Have Donated |
The MAP sensor has been replaced. While doing this, I noticed that there seemed to be a node for a vacuum line with no line attatched. I'm attatching pictures, what do you think?
| Find a
Posted at Fri May 30, 2008 11:44 pm |
By
Buzzsaw,
Moderator |
| zahmin89 wrote: | The MAP sensor has been replaced. While doing this, I noticed that there seemed to be a node for a vacuum line with no line attatched. I'm attatching pictures, what do you think? |
thats crusie controlie lol, you either got plug wires crossed or something wrong, when was the map sensor replaced?
| Find a
Posted at Tue Jun 24, 2008 9:43 pm |
By
zahmin89,
Have Donated |
About a week before I made the post that I had done it. Is that node there something I should worry about? Or not really?
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
