Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1995 Cadillac El Dorado why is car overheating
Posted at Sat Nov 07, 2009 7:36 pm |
By
2hotride,
New to the forum |
Give Feedback | Votes: 0 |
Engine Cooling problem
1995 Cadillac El Dorado Automatic
how do I determine why Northstar engine keeps overheating? |
Find a
car repair manual for your Cadillac El Dorado Repair Question.
Posted at Sun Nov 08, 2009 10:39 am |
By
gstacey,
Moderator |
(157) Give Feedback | Votes: 31 |
An overheat can have different characteristics that give indications to what might be causing it. If it is showing overheat, and you can wrap your hand around the upper radiator hose without it being too hot, you may have a thermostat that is stuck closed. If it is overheating after running hard, it could mean an internal leak like a headgasket, cooling fans that are failing to operate, or restricted airflow across the radiator. If the upper radiator hose is hot to the touch, you can have a block test performed that may indicate internal leak by detecting the presence of combustion gases in the cooling system. Obvoiusly low coolant level can cause overheat, a pressure test is also a good choice. A missing water pump belt would cause an overheat. Although it is rare, a faulty water pump could be cause. The best bet, is to have some diagnostics run before throwing parts at it. Head gasket leaks are a common failure on these, and an expensive repair. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
