Car Repair Forum - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1995 Cadillac Deville Too much oil
Posted at Sun Nov 01, 2009 10:38 am |
By
barneysny06,
Likes to hang around! |
Give Feedback | Votes: 0 |
Engine Performance problem
1995 Cadillac Deville 4 cyl Automatic
For some reason, I'm losing oil. It's not dripping in puddles but I'm losing it. I was out running errands yesterday and I stop for gas and I checked my oil level and it was so dry inside the engine. I had just put in some oil earlier this week (about 4 quarts, 5 is the max capacity) and I added 3 quarts yesterday. As soon as I added the oil and started up the car, it jerked and shook a little and then it drove ok. Even today, Whenever I stop at a traffic light, it jerks a little right at take off. Did I add too much oil? |
Find a
car repair manual for your Cadillac Deville Repair Question.
Posted at Sun Nov 01, 2009 10:59 am |
By
rasmataz,
Certified 2CarPros Master Technician |
        (8489) Give Feedback | Votes: 230 |
Whenever I stop at a traffic light, it jerks a little right at take off. Did I add too much oil? The oil has nothing to do with it jerking. Could be one of the following.
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires |
Find a
Posted at Tue Nov 03, 2009 2:24 pm |
By
barneysny06,
I took my car to my mechanic this morning and he added some gas treatment by STP to my tank. Should I purchase some fuel injector fluid to my gas as well because it's still doing some jerking but it's a little better than it has been. |
Find a
Posted at Wed Nov 04, 2009 7:25 am |
By
rasmataz,
Good idea on the fuel injector cleaner |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
