Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
1995 Buick Roadmaster V8 Two Wheel Drive Automatic 120000 miles
WHEN I START MY CAR AND GO TO ENGAGE THE BRAKE MY CAR STALLS OUT. WHAT IS WRONG
Hi:
It sounds like there is a problem at the power brake booster causing a drop in vacuum to the engine. Disconnect the hose going to it, plug it, and see if the same problem still happens. Keep in mind, you will not have power assist to the brakes.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
