Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2004 Infiniti G35 Repai...
Auto Repair2001 Chevy Blazer Fuel ...
Auto Repair1998 Buick Century Left...
Auto Repair1998 Other Plymouth Mode...
Auto Repair1999 Chevy Venture Over...
Auto Repair1991 Jaguar Xj6 Power S...
Auto Repair1996 Chevy Truck Hot Ma...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 Buick Riviera Check engine light
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Oct 15, 2008 5:44 am
By jwoolums, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1995 Buick Riviera 6 cyl Front Wheel Drive Automatic 168000 miles
I have a 95' Riviera with a supercharger. The supercharger has been replaced, it has had all new plugs, wires and three new coils. I have had the transmission serviced and have oil changed regularly and add fuel additive every other tank. When drive I feel a vibration and with my experiece I feel it is a combustion issue. After a few minutes driving the check engine light comes on and it is to the point that I can tell when it will happen (usually once I reach 40 MPH and then let off the throttle). The testing device says the check engine light is emmission related and could be one of three things; the EGR valve, the O2 sensor or an electronic fuel sensor. This car is running better than ever and I even get 24 MPG but this rough idle vibration is driving me nuts. One other note; sometimes when I start the car back up after only sitting a few minutes, it has a toughtime staying running so I have to do a power brake take off until it straightens out in a few seconds. Do these symtoms suggest a bad EGR?
Find a car repair manual for your Buick Riviera Repair Question.
Posted at Wed Oct 15, 2008 1:54 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
Posted at Wed Oct 15, 2008 2:06 pm
I have no idea how your post is supposed to help. You asked no question and you show some diagram as to entering diagnostic mode. First off, I have already had a mechanic do that. Second, what am I supposed to jump those two connectors with? Third, how is that going to help?
Why don't you try typing a question or give me some feedback to my detailed post.
I have no idea what you are wanting. Is this all the help a $10.00 donation gets? What a rip-off.
Posted at Thu Oct 16, 2008 9:30 am
By 2CarPro Jack, Certified ASE Technician
Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8Reputation: 683.8 (684) Give Feedback | Votes: 80
Use a piece of wire or paper clip to jump the two and count the flashes, this will give the code that the computer stored.So the vibration feels like a misfire? The way you describe it , it could be an EGR issue or possibly a weak injector. Those 3.8's had some issues with injectors.The stalling after restart could also be an injector issue as well, or possibly a idle speed control motor.Try removing the isc motor and cleaning it with carb cleaner.
Posted at Thu Oct 16, 2008 11:16 am
Hello Jack and thanks for the response. This started after I had the superchager replaced and I thought it was a misfire. I replaced the three coils and it still ran rough so I took it back to the mechanic and he replaced the wires and plugs. This vibration did get less noticeable but it still did not run like it had before. I only replaced the supercharger because the bearings were shot and it was making a lot of noise. The mechanic told me he cleaned the throttle body when he reassembled but I will try and clean the injector item you mentioned.
Posted at Thu Oct 16, 2008 11:56 am
Do oyu get the vibration at idle? If so try removing and securing the supercharger belt out of the way and starting it to see if the vibration goes away
Posted at Thu Oct 16, 2008 12:26 pm
Yea Jack we have tried that as well. In fact, I was so convinced that it was maybe a warped turbine or misaaligned pulley that I got the supercharger replaced as the company I bought it from gave me a lifetime warranty.
Posted at Thu Oct 16, 2008 12:44 pm
I did type in the instructions on my post, but sometimes when we upload the pictures, it clears the text, sorry. What I would like to know is if you already read the codes, what were they? This will be of some help, since we are diagnosing over the web! Here are the instructions to do it yourself, use the picyure above...Cross these two terminals as shown, then turn the key on. Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 12. Write them down and post here. This connector is right under the middle of the dash...
Posted at Mon Oct 20, 2008 12:43 pm
Hello Merlin,
Sorry to just be getting back but I got pretty ill fo a few days. Today I tried sticking a paper clip into the first two spots of the connector and then turned the car on. I tried the first two from both ends since the plug does not really look like your diagram. I did this several times with each but I saw nothing flashing as in lights or numbers. Can you advise?
Jim
Posted at Tue Oct 21, 2008 10:25 am
Yep..maybe! Some 95's have the newer OBDII connector, on all 96 and new cars, if it looks like this, scan with an OBDII scanner, Autozone does it free, or you can buy one here.
http://www.2carpros.com/affiliate/uid/merlin2021_1
Hope you feel better!
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
