Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2004 Nissan Sentra Serv...
Auto Repair1999 Mercedes Benz Ml320...
Auto Repair2008 Toyota Camry Does ...
Auto Repair2001 Jeep Wrangler Engi...
Auto Repair2000 Chevy Silverado
Auto Repair2000 Jeep Wrangler Brak...
Auto Repair2000 Chevy Impala Rubbe...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 BMW 318 Overheating
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Jun 27, 2008 10:47 am
By ArchMedic, Have Donated
Give Feedback | Votes: 0
Engine Cooling problem
1995 BMW 318 4 cyl Two Wheel Drive Automatic 155000 miles
1995 BMW 318is, 155,000mi
I recently purchased this car (very cheaply, knowing it had issues). Currently it is badly overheating. The previous owner had it in the shop, and they replaced the thermostat and coolant pump. (I verified this) I have flushed the system (engine and radiator), drained and filled the system several times. When I start it up, it remains cool briefly, then the temp gauge continues rising without stopping until it overheats. At this point, the fan has kicked on, and the system is pressurized, but both hoses are very hot. The radiator is in pristine shape from the outside. So basically from what I can verify, all the components are working, but the system doesn't seem to be cooling at all.
At this point, should I suspect a blown head gasket? This was suggested, but there doesn't seem to be anything but oil in the oil, the coolant is clean, and no smoke or steam coming from the tailpipe. Would a head gasket cause the above? Is there anyway to verify a problem before I undertake the project?
Additionally, the heater isn't blowing any heat, even on the hottest setting. I don't know if this is relevant, if not it isn't a concern as it is summer in NC. Any suggestions, solutions, or even just directions to take would be helpful. Thanks!
Find a car repair manual for your BMW 318 Repair Question.
Posted at Fri Jun 27, 2008 11:06 am
By mmprince4000, Moderator
Reputation: 76.4Reputation: 76.4Reputation: 76.4Reputation: 76.4 (76) Give Feedback | Votes: 4
Have a compression test performed on the engine. A head gasket or cracked head can cause the engine to overheat and in some cases you will not see coolant in the oil or white smoke out the exhaust.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
