Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2002 Ford Mustang
Auto Repair1998 Other Nissan Models...
Auto Repair1997 Buick Lesabre
Auto Repair1999 Gmc Jimmy
Auto Repair1994 Ford F150 Fuel Pum...
Auto Repair2000 Ford Contour Tryin...
Auto Repair2001 Cadillac Deville N...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 BMW 318 Over heating.
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Thu Jun 12, 2008 8:39 am
By Katie1987, New to the forum
Give Feedback | Votes: 0
Engine Cooling problem
1995 BMW 318 4 cyl 155000 miles
I have BMW 318is I had coolent leak and I took it in. They replaced a hose under the intake and the Rad. They spent alot of time getting all the air pockets out and took it for a road test. On the road test the car started to over heat. They brought it back in. Did a compression check it was fine checked the water pump. it was fine. now they are beleeding the system to rule out poss air pockets... they also checkt he thermostat and they said that was stuck open which wouldnt be a probem.. HELP!!!!
Find a car repair manual for your BMW 318 Repair Question.
By Advertisment,
Posted at Thu Jun 12, 2008 9:17 am
By Dr. Hagerty, Moderator
Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378Reputation: 378 (378) Give Feedback | Votes: 8
The thermostat should be replaced and then run the car again to see if it overheats. Is the auxiliary fan working? Is the fan clutch engaging?
Posted at Thu Jun 12, 2008 4:17 pm
By grekgeek, New to the forum
Katie the mechanic MUST perform a compression test on the 4 cylinders. The PSI readings of each cylinder will provide the mechanic with the feedback he needs to diagnose the area.
I assume the compression test you are talking about is the one where the mechanic pumps up the cooling system with air pressure to like one would do to see if a tire was leaking.
I am surprised that they have not performed the cylinder compression test yet.
Dye liquid inserted into the cooling system will hopefully leak and once a black light is shined on it you will see where the leak is. Some people inject the lead type substance into the cooling system that seals leaks. My take on that stuff is that people use it to fix up there car to sell it. I would not stand behind any problem that this chemical compound can patch over the long run.
My advise to you is cut you losses and get rid of the car if you cannot afford to spend the money to fix the problem correctly. See if the lead stuff can fix the problem temporarily and then sell the vehicle while it is still working.
Good luck.
Sam
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
