1995 Audi A4 6 cyl Two Wheel Drive Manual 107,00 miles
I am only able to get hot air from the A/C. The gas is ok, but the controls on the electronic display do not seem to be doing what they say they are doing. Ie no fresh air even though the light is on. Hot air is only comming through the top vents. when switched to floor or face, the system does not change, again even though it says it has!! If i set the temp at LO, the heat is just the same as high.
Anybody help??
