Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1995 Acura Integra 4 cyl Front Wheel Drive Manual
when i try to crank it it cranks but it won't start. i replaced the distributor and the plug wires but it still will not start. it is getting fuel, and all wires are firing and they are in the correct order.
try running a compression check on all four cyld. the compression should be between150 psi to 175psi may be a little higher or a little lower but they should all be some what close to each other
IF YOU HAVE A CYLD WITH LOW COMPRESSION try putting a little engine oil down the the spark plug tube then check the compression again if it builds up on that cyld you probably have a burnt valve
Double check and make sure every thing i correct before checking this step and all the electrical connectors are connected and as well as the ground strap behind the distributor on the thermostat housing
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
