Engine Cooling problem
1995 Acura Integra 4 cyl Front Wheel Drive Manual 102000 miles
I was recently driving and my car started smoking (white) on the right side. I added a 50/50 mix of coolant to the car. However, after about 10 minutes of driving the temperature rises and the white smoke starts coming from under the hood. Do you know what's wrong with it?
Find a
repair manual for your Acura Integra Repair Question.
Posted at Wed Apr 30, 2008 1:55 pm
By
Advertisment,
Find a
You will have to get a pressure test done, this will locate any external coolant leaks, also have a head check done just in case you also have a head gasket issue as well, as white smoke from the exhaust is a good sign of this problem.
Mark (mhpautos)
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
