Air Conditioning problem
1995 Acura CL 4 cyl Two Wheel Drive Automatic 12313 miles
ac doesnt blow any air
Need to start by checking all fuses. Then if ok, go to blower (under dash r/h side) and using a test light check for power at the motor with the switch in all positions.If you have power, verify the ground, if it is ok as well the blower motor is bad.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins.Click
here to find out more.
