Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Transmission problem
1994 Toyota Pickup 4 cyl Two Wheel Drive Manual 16000 miles
what will cause the clutch to begun to be hard to mash
All clutches require a certain amount of pedal effort, but if the pedal feels unusually stiff or hard, check for sticking or binding in the pedal linkage, cable, crossshaft, fork or pivot ball. A blockage or worn seals in the hydraulic system also can increase pedal effort.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
