Auto Repair Talk - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1994 Toyota Corolla Not shifting
Posted at Mon Nov 02, 2009 9:44 am |
By
dexter727,
New to the forum |
Give Feedback | Votes: 0 |
Transmission problem
1994 Toyota Corolla 4 cyl Front Wheel Drive Automatic 160000 miles
I was wondering if there is anything that I can do to possibly fix this problem
I have to allow my car to warm up, before it will shift into overdrive. If i do not it stays stuck in 3rd gear and will not shift untill it is warmed. The moment the gauge on the coolant temperature rises above the very bottom line it will shift.
Also, along the lines of the coolant temperature gauge, if I am driving and the gauge goes below the bottom line, my transmission will not go into the more fuel efficient overdrive, or will shift out of it if I had been in that gear at the time.
I don't really know a whole lot about cars, so i apologize if my vocabulary is off.
Thank you |
Find a
car repair manual for your Toyota Corolla Repair Question.
Posted at Tue Nov 03, 2009 6:53 am |
By
mmprince4000,
Certified 2CarPros Technician |
                     (2159) Give Feedback | Votes: 35 |
You probably need a new thermostat.
Many transmissions will not shift into OD untill the engine is in "closed loop", in other words, the engine is at operating temp, usually 195 degrees.
A bad thermostat will not allow it to get to operating temp. |
Find a
Posted at Tue Nov 03, 2009 12:15 pm |
By
dexter727,
New to the forum |
How much would it generally cost to have a new thermostat put in?
Or is it something that can be fixed very easily? |
Find a
Posted at Wed Nov 04, 2009 3:58 am |
By
mmprince4000,
Never use the "easy" word .
You drain about a gallon of coolant, remove thermostat housing, and thermostat, replace thermostat and seal, bolt housing back on.
Use a Toyota brand part and make sure "bleeder" in thermostat housing is pointing at 11:00. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
