Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
1994 Pontiac Bonneville
hello i have an problem i have change my ignition wire set and now it is not in order can you send an picture for me that i can see how it is.
please contact me so soon.
please i need it
Find a car repair manual for your Pontiac Bonneville Repair Question.
You can start with either one ,but make sure the wire are in the right order before starting the engine .Also if you didn't know the ,"1" on the coil matches up with the number ,"1" cylinder . and ," 2" on the coil goes to the number ,"2" cylinder ext...
Let me know If I helped you any .
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
