Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Transmission problem
1994 Other Isuzu Models 6 cyl Two Wheel Drive Manual 68000 miles
iv replaced the master and slave unit on the clutch iv bled it 10 times the pedal works fine for a few days then starts slowlys going down iv check for leaks theres none what could cause this
I assume when you rebleed it is O.K. If so try this put a clear plastic tube on bleeder place into a contanier of fluid. Open bleeder have someone pump pedal, until no more bubbles. Keep eye on master fluid level.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
