Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1994 V8 Two Wheel Drive Automatic
i have a buick roadmaster that the front main seal was replaced on and the oil pan seal was replaced but it leaks oil somewhere near the oil pan it actually looks like its leaking above the oil panit gets all over the converters and flywheel which causes it to smokei at least need to know where to start looking what to try ive tightened every bolt and nut i can find a list of trial and errors would be wonderful thankyou please reply asap
If there is no visible leak from the rear of the heads, valley cover or rocker covers that may be running down, i feel that the rear main oil seal is leaking , if so the transmission will have to be removed to access it.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
