Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1994 Nissan Altima 4 cyl Front Wheel Drive Automatic 234000 miles
According to computer code, I replaced the knock sensor.That code is cleared now and computer is reading good. However, the car still runs rough and has died on my wife. Have I missed something or does the system need to run longer to straighten out?
The knock sensor is just one part of the engine management system, if you have no codes set, i would be doing a general tune up plugs, leads if old, fuel & air filters and have a run on an oscilloscope as this will identify any ignition problem that may be causing your fault.Start here.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
