Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1994 Jeep YJ wont start
Posted at Thu Oct 15, 2009 8:10 am |
By
David Patterson,
New to the forum |
Give Feedback | Votes: 0 |
Electrical problem
1994 Jeep YJ 4 cyl Four Wheel Drive Manual 150000 miles
wont start in the morning, turn the key on and cranks, cycle the key on and off several timer, fuel relay under hood starts clicking and can hear purging of fuel but still wont start until after seversl cycles later. I have cleaned body to chassie ground and enging ground. what else can i do? |
Find a
car repair manual for your Jeep YJ Repair Question.
Posted at Thu Oct 15, 2009 1:24 pm |
By
rasmataz,
Certified 2CarPros Master Technician |
                             (14900) Give Feedback | Votes: 349 |
Don't cycle the key anymore when it refuses to start do below to determine if its fuel or spark problem could very well be the ignition switch
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
