Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1994 Jeep YJ Transmission Overdrive
Posted at Wed Sep 02, 2009 3:04 pm |
By
Louisejeep,
New to the forum |
Give Feedback | Votes: 0 |
Transmission problem
1994 Jeep YJ 4 cyl Four Wheel Drive Automatic 150000 miles
SOMETIMES ONLY, when it goes into overdrive between 70 an 90 km/hr it jumbs between drive and overdrive, drive and overdrive and does not stop even if I go faster. Other times it won't do it at all. I had all the sensors change excepte the ECM, tried 3 different TPS because the Jeep keeps giving the TPS code. Had the trani checked and ajusted, I was told it was not the trouble because it does not do it all the time. Had all the tranni connections cleaned and checked. It's been doing this for about a year now and I am running out of patience. Today I was checking my fluids like I usually do once a week and check the wires for the battery, the distributor cap and the coil to make sure they were tight. Got into my jeep and whent to start it, nothing happened, the lights in the dash were nice and strong but that's it. So I went back under the hood and played with the coil wire, then it started. The end of the wire connecting to the coil has always felt soft like easyly pliable, could the trouble of the trani be caused by a deffective coil wire???
PS/ If you find the awnser I will donate as soon as I get a little loose. My budget is really small, I am presently out of work because of an injury. Thanks for understanding. Louise |
Find a
car repair manual for your Jeep YJ Repair Question.
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
