1994 Honda Accord CAR STALLS WHEN BREAKING HARD WITH LOW FU
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1994 Honda Accord 4 cyl Two Wheel Drive Automatic 133000 miles
MY 94 ACCORD STALLS WHEN BREAKING HARD WHEN I GET BELOW A 1/4 TANK OF FUEL. I HAVE REPLACE THE SENDING UNIT BUT THAT WAS NOT THE PROBLEM. ANY SUGGESTIONS.
The sending unit would have nothing to do with fuel supply.
Most probably the fuel pump bowl in the tank is detached resulting in sloshing of the fual and when braking hard, there is not enough fule supplied by the pump causing the engine stalling. You need to check the fuel pump and tank.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
