Car Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
1994 GMC Sierra Gradually decreasing power
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Wed Sep 03, 2008 12:57 pm |
By
Keithsmoot,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
1994 GMC Sierra V8 Two Wheel Drive Automatic 206K miles
The truck would lose power initally with the "check engine" light on. Within 100 miles or less the power loss was more dramatic, to the point of barely able to move. I could pump the gas peddle and get some power, but not much. The engine seemed to idle nicely for a while, the cut off, especially at the end. The engine will turn over and start well. The truck sits most of the time, water in the gas? Electronic ignition module? Fuel pump? How do I test the (in-tank?) fuel pump in my basement? Could I be completely off the mark? One note; the truck would run just fine at first, but when the "check engine" light would come on, the power loss would start. Waiting for the truck to cool down did not help.
| Find a
car repair manual for your GMC Sierra Repair Question. |
Posted at Thu Sep 04, 2008 10:42 am |
By
Keithsmoot,
Have Donated |
to Mastermechanictim,
I jumped A and B and counted three flashes of the check engine light. They were, one flash, brief pause, then two closely spaced flashes.
Thanks,
Keith
| Find a
Posted at Sat Sep 06, 2008 4:06 pm |
By
Keithsmoot,
Have Donated |
I tried to jump the A and B terminals again. The 1-2 sequence repeated three times, then the check engine light flashed four times, paused then flashed four times, paused, four flashes, paused, ect. Is this what you were looking for?
Thank you,
Keith
| Find a
Posted at Thu Sep 11, 2008 3:07 am |
By
Keithsmoot,
Have Donated |
Thank you for your ideas. Using additional sources I replaced the fuel pump and that appears to have done the trick. At least the truck will start now. The rain has prevented me from taking the truck out of my back yard, but things look better!
For some time the check engine light has come on and then gone off for no apparent reason. I will check the wires and sensors you suggest.
If the problem persists when I can drive the truck I will give you another call.
Thank you,
Keith
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
