Auto Repair Help by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1994 Geo Tracker over heating
Posted at Wed Nov 04, 2009 9:44 am |
By
thelourds,
New to the forum |
Give Feedback | Votes: 0 |
Engine Cooling problem
1994 Geo Tracker 4 cyl Four Wheel Drive Automatic 70,000 miles
The heat is great, just replaced the radiator & thermestate. But while driving it over heats, but not at idle. |
Find a
car repair manual for your Geo Tracker Repair Question.
Posted at Wed Nov 04, 2009 10:03 am |
By
bluelightnin6,
Certified 2CarPros Technician |
            (6723) Give Feedback | Votes: 227 |
are your cooling fan(s) coming on properly? |
Find a
Posted at Wed Nov 04, 2009 10:05 am |
By
rasmataz,
Certified 2CarPros Master Technician |
                            (14592) Give Feedback | Votes: 346 |
Do you have an actual boiling over or just the gauge that's telling you that it is?
Cooling fan/s coming On? if okay test the water pump
One way to test for a bad water pump is to squeeze the upper radiator hose when the engine is hot and idling. Careful, because the hose will be HOT! If you do not feel much coolant circulating through the hose when you rev the engine, the pump may be bad.
If it continues to overheat-Get it block and pressure tested. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
