Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Ford F350 Oil Pan ...
Auto Repair2005 Dodge Caravan Powe...
Auto Repair2000 Chevy Impala Rubbe...
Auto RepairLets Welcome Our Newest ...
Auto Repair2005 Gmc C2500 Speedopm...
Auto Repair2002 Dodge Neon Radiato...
Auto Repair1997 Hyundai Tiburon Wo...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1994 Ford Ranger truck seems to miss a cylinder when idle
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2, 3  Next
Posted at Wed Aug 27, 2008 3:17 pm
By kbhatia007, Likes cars!
Give Feedback | Votes: 0
Engine Mechanical problem
1994 Ford Ranger 6 cyl Two Wheel Drive Automatic 262000 miles
After a long dedicated 14 years, thhr ranger is beginning to act up. Have replaced fuel pump, fuel filter, spark plugs wires etc. but the engine seems to be missing firing on a cylinder when idling. When under power, it seems that the truck is going to buckle over and shudders very badly. the fuel pressure is good @45psi.The transmission has about 160000 on it. It was running ok till I decided to do some PM on it and has never been like before. Every mechanic has pointed in every different direction. the truck passed emissions with flying colors two weeks ago when the problem was intermittent. Now it is continuous. compression in cylinder 3 is 75psi(as per the repair shop). What should I do next and what is the problem?
Thanks for your help......
Find a car repair manual for your Ford Ranger Repair Question.
Posted at Wed Aug 27, 2008 6:17 pm
By blackop555, Certified 2CarPros Master Technician
Reputation: 107.4Reputation: 107.4Reputation: 107.4Reputation: 107.4Reputation: 107.4 (107) Give Feedback | Votes: 27
260,000 miles is phenominal.
it may be time for a engine overhaul, sounds like the rings are wearing, how did a wet compression test handle? the pressure go up significantly?
75 is pretty low and will definetely make a missfire very noticble at low speeds.
Posted at Thu Aug 28, 2008 4:19 am
Will be doing a wet test in a couple of days, but everybody wants me to swap the engine out, which I am very hesitant to do....Want to rebuild the head and the valves if that sounds like it will solve the problem. If the pressure comes up with the wet test then only I will swap the engine.......(indicating bad rings)... we will know pretty soon.
Posted at Thu Aug 28, 2008 11:20 am
rebuilding the heads as you suggest could work if the rings arent worn.
might be time to checking the bearings also. the rings could be worn, the cylinders are probably worn.
Posted at Thu Aug 28, 2008 3:59 pm
Thanks blackop555 Smile)
We will know better tomorrow after the wet test. i think that will decide if I need to swap the engine of work the valves and the heads. I really do appreciate your input. Let us wait and seee...........
Posted at Thu Aug 28, 2008 5:51 pm
no problem, i hope the best cheapest way for you!
if you need further assistance im here to help!
Posted at Fri Aug 29, 2008 10:39 pm
Hello blackop555:
This time did the compression test myself and found that all cyls had roughly 170psi after 5 piston strokes.....
too high but seems to me that the mechanic could be wrong.........now does that point to a clogged convertor? two independent mechanics have already told me that there is metal coming out of the tail pipe.....truck drove smooth after I assembled the plugs back in the cylinder
really confused now???...,,,,,
Posted at Sat Aug 30, 2008 6:00 am
hmm 170psi is a bit high, maybe a camshaft issue wouldnt worry as long as its runnign good now, could be that a spark plug wire was loose on the plug or damaged and when you were moving them around it made the wire complete connection again.
would like you to check on that one cylinder momentarly see if when the engine runs rough if the compression drops back down.
Posted at Sat Aug 30, 2008 12:13 pm
I realy appreciate you hanging in there for me and geting me through this, blackop555.........
It is back to where we started. i will run over the truck to a muffler place to make sure the converter is not clogged. There are two holes on the side and I can feel the exhaust coming out of there. It has not run bad on idle and city driving like before, but definitely feels as if it is missing.....the same vibrations on park and idle and same when the transmission is engaged with brakes on............the worst part is tat it is not displaying any codes....says everything is good......
Posted at Sun Aug 31, 2008 12:40 pm
thats what im here for.
chances all that would show up is a missfire code. but since pre obd2 didnt have missfire detection. it wont show up.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
