Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair2001 Mercedes Benz 320e ...
Auto RepairMy Renault 19
Auto RepairDrive Does Not Engage
Auto RepairRenault Traffic T1100 Pr...
Auto Repair2003 Other Renault Model...
Auto Repair2004 Other Renault Model...
Auto RepairHow To Replace The Throt...
Auto Repair More Repair Topics...
Free Auto Repair Advice by Professional Mechanics
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1994 Ford Mustang Trouble code 212 how to fix
Posted at Thu Jul 02, 2009 6:17 pm
By almtyscuzzy, Have Donated
Give Feedback | Votes: 0
Electrical problem
1994 Ford Mustang V8 Two Wheel Drive Manual 100,00 miles
This code 212 is driving me crazy, can't seem to fix it. I followed the procedure below along with my findings. My answer is after each procedure.
3) Check IDM Circuit Continuity
Turn ignition off. Disconnect 60-pin PCM connector. Inspect connector for damaged pins, corrosion and loose wires. Repair as necessary. Install EEC-IV Breakout Box (T83L-50-EEC-IV), leaving PCM disconnected. Disconnect ICM. Measure resistance between test pin No. 4 at breakout box and IDM circuit terminal at ICM wiring harness connector. If resistance is less than 5 ohms, go to step 5). If resistance is 5 ohms or more, repair open circuit, and repeat QUICK TEST . (I got 0.5 ohms)
NOTE:A break in step numbering sequence occurs at this point. Procedure skips from step 3) to step 5). No test procedures have been omitted.
5) Check IDM Circuit For Short To Power (Except VREF)
Turn ignition off. Leave ICM and PCM disconnected. Measure voltage between breakout box test pin No. 4 and negative battery terminal. Turn ignition on. Measure voltage between test pin No. 4 and test pins No. 40 and 60 at breakout box. If any reading is more than 10.5 volts, repair short circuit. Clear codes, and repeat QUICK TEST . If both readings are 10.5 volts or less, go to next step. (I got 0vdc is this correct.)
6) Check IDM Circuit For Short To PIP & VREF
Turn ignition off. Leave PCM and ICM disconnected. Remove scan tool (if applicable). For shorts to PIP, measure resistance between test pins No. 4 and No. 56 at breakout box. For shorts to VREF, measure resistance between test pins No. 4 and No. 26 at breakout box. If either resistance is 10,000 ohms or less, repair short circuit. Remove breakout box, reconnect all components, and repeat QUICK TEST . If each resistance is more than 10,000 ohms, go to next step. (I got an open here or infinite resistance)
7) Check IDM Circuit For Short To Ground
Turn ignition off. Leave ICM and PCM disconnected. Measure resistance between test pin No. 4 and test pins No. 20, 40, 46 and 60 at breakout box. If each resistance is more than 10,000 ohms, go to next step. If any resistance is 10,000 ohms or less, repair short to ground in IDM circuit. Remove breakout box, reconnect all components, and repeat QUICK TEST .
Check ICM . I got no resistance or infinite resistance)
8)Turn ignition off. Connect PCM to breakout box. Reconnect ICM to wiring harness connector. Connect DVOM between test pins No. 4 and 16 at breakout box. Start engine. Observe DVOM for voltage surge while lightly tapping on ICM and Camshaft Position (CMP) sensor (if equipped) to simulate road shock. Wiggle all ICM and CMP sensor wiring and harness connectors. If fault (voltage surge) is not indicated, go to next step. If fault (voltage surge) is indicated, disconnect and inspect wiring harness connectors and terminals for damage. Repair as necessary. If connectors and terminals are okay, check ignition system. See the I - SYSTEM/COMPONENT TESTS - EEC-IV (5.0L) article.
9) Check PCM & Harness Connectors
Ensure engine is still running and DVOM is still connected between test pins No. 4 and 16 at breakout box. While observing DVOM, wiggle and bend wiring harness, a small section at a time, from ICM and CMP sensor (if equipped) to cowl. Also, check harness from cowl to PCM. If fault is indicated, isolate fault and repair as necessary. Remove breakout box, reconnect all components, and repeat QUICK TEST . If no fault is found, go to next step.
My voltage moved from 12.45 vdc to 12.26 or a little hiher like 12,56 but I am using a big aftermarket camshaft.
10) Check PCM & Harness Connectors
Turn ignition off. Disconnect PCM 60-pin connector. Inspect connector for damaged pins, corrosion and loose wires. Repair as necessary. If connector is damaged, repair as necessary. Remove breakout box, reconnect all components, and repeat QUICK TEST . If connector is okay, go to next step.
Connector looks fine.
Find a car repair manual for your Ford Mustang Repair Question.
Posted at Thu Jul 02, 2009 6:59 pm
By jnovack, Moderator
(58) Give Feedback | Votes: 6
I would first inspect the SPOUT connector that is by the distributor. It is a single harness that has a plug at the end of it. Perhaps it is missing this plug and the computer is not advancing the timing and producing this error. My book also says it is "Loss of Ignition Diagnostic Monitor (IDM).
after you check to see if your spout is there..........i would go ahead and check your engine timing.........remember to do this with the spout removed........once you know your timing is set, shut off the vehicle and check all of your connections around the distributor.....like the harness that goes to the tfi, which sits on the side of your dist....be sure all of your wires at the coil are clean too.........i usually clean the connections, then use dielectric grease on the connections before i install everything back
Posted at Thu Jul 02, 2009 7:04 pm
The spout connector is there and I checked it and it has continunity. I also checked the wires from the spout connector and they do trace back to TFI module and the computer (EEC-IV). So no breaks there.
Timing is fine. with this code 212 what am I looking for? A short somehwere?
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
