Computer problem
1994 Ford F250 V8 Four Wheel Drive Automatic 106 miles
How do I read the malfunction code without a scanner, I know where the diag connector is under the hood, but cannot find the wire to jumper pin 2 to read the code at the warning light or do i use a multi meter to get the codes? The truck runs fine with the warning light on.
