Engine Mechanical problem
1994 Ford F150 6 cyl Two Wheel Drive Manual 300000 miles
hello. my truck runs a bit rough on idle and hesitates and misses under load. im in the process of checking ignition timing and have tried to locate a spout connector but no joy. the timing light shows its either way off or somethings wrong. how do i adjust the ignition timing? ive checked the distibutor and rotor everything is relitivly new from previous owner.
