Engine Mechanical problem
1994 Ford F150 6 cyl Two Wheel Drive Automatic 90000 miles
i have a haynes manual it says that if the engine is still in the truck you can put it in gear to keep the crank shaft from turning but when i try remove the bolt the shaft still turns? does anyone know what i should do
