Car Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
1994 Ford Explorer oil level keeps rising
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Sun Aug 10, 2008 1:59 pm |
By
richgroup,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic
I did an oil change about a month because my oil level was almost twice what it should be. It ran good and then started running ruff. I checked my oil and it was up about 3-4 liters. There's nothing like anti freeze or tranny fluid or water on the dipstick. It's clean and just oil.
I am absolutely baffled by this.
| Find a
car repair manual for your Ford Explorer Repair Question. |
Posted at Sun Aug 10, 2008 2:24 pm |
By
richgroup,
Have Donated |
But what will cause the oil level to rise? I have never had to add oil, except when changing which is done every 5K
If there's nothing leaking in, how does the level rise?
| Find a
Posted at Mon Aug 11, 2008 8:45 am |
By
richgroup,
Have Donated |
The oil level has always been right where it should be. I have not had to add oil between changes. I realize it could be fuel from maybe a faulty injector, but it doesn't smell of fuel...it looks very clean on the dipstick.
| Find a
Posted at Mon Aug 11, 2008 4:10 pm |
By
richgroup,
Have Donated |
But if there is only 4-5 liters of oil in there, how can the level keep rising and end up with more then you started with?
| Find a
Posted at Mon Aug 11, 2008 6:21 pm |
By
richgroup,
Have Donated |
Thank you very much for all you input. I will try your suggestions.
Thanks again.
Ron
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
