Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1995 Chevy Blazer Raw G...
Auto Repair1996 Chevy Beretta
Auto Repair2006 Chevy Trailblazer ...
Auto Repair2002 Gmc C1500 Trans?
Auto Repair1992 Lexus Sc 400 Failu...
Auto Repair1996 Plymouth Breeze En...
Auto Repair2007 Cadillac Escalade ...
Auto Repair More Repair Topics...
Car Repair Chat - Ask a Question, Get a Free Answer
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1994 Dodge Shadow over heating
Posted at Mon Jul 27, 2009 6:22 am
By slick0047, Have Donated
(7) Give Feedback | Votes: 0
Engine Cooling problem
1994 Dodge Shadow 4 cyl Front Wheel Drive Automatic 122000 miles
Hellom,
This has been an ongoing problem, just last week i had new heads put on and gasket kit, new themostat, i have installed new sending unit and thermostat temp sensor, the engine will heat up all the way to the line just before Hot and then slowly climb back down, this happens with the A/C on or off. Currently with the A/C on it stays just above the second line from the Cold. I have replaced the heads on this car 3 times now. I have been told i may have a air bubble, i have cleaned out the cooling system using Preston coolant cleaner, ran if for about a week and then replaced all the coolant with new stuff. there is a hex screw in the thermostat housing unit i was told to loosen and this would allow the possible air bubble to escape? I cant remove it, it is stuck so i need solution to that, and the over heating problem, thanks.
Robert
Find a car repair manual for your Dodge Shadow Repair Question.
Posted at Mon Jul 27, 2009 7:43 pm
By ImpalaSS, Certified 2CarPros Technician
Reputation: 1080.4Reputation: 1080.4Reputation: 1080.4Reputation: 1080.4Reputation: 1080.4Reputation: 1080.4Reputation: 1080.4Reputation: 1080.4Reputation: 1080.4Reputation: 1080.4Reputation: 1080.4 (1080) Give Feedback | Votes: 27
Hello –
To better assist you is your model just the Shadow or the Shadow ES? Also what is your engine size in liter?
Yes you need to replace the housing with the hex screw to assist in getting the air out.
How long ago did it start doing this?
Lift the hood. Turn off the AC and fan. Start the engine when cold. The radiator fans should not be turning. Are they?
Now reach inside and turn the AC on high. Are the fans spinning? They should be?
When the car is warmed up………and you turn the heater on does it blow hot?
When was the last time you changed your radiator cap?
Have you ever changed your water pump?
Thank you very much for the donation
Please let us know if what the final fix was for your car so we can better assist others. Thanks!
Find a car repair manual for your car repair questions.
Posted at Sat Aug 01, 2009 1:35 pm
Hello –
To better assist you is your model just the Shadow or the Shadow ES? Also what is your engine size in liter? ----------Std and 2.5 liter
Yes you need to replace the housing with the hex screw to assist in getting the air out. ------How its stuck almost stripped the hex nuts last time?
How long ago did it start doing this? ------------it has been doing this on and off for about 3 years
Lift the hood. Turn off the AC and fan. Start the engine when cold. The radiator fans should not be turning. Are they? ----------NO
Now reach inside and turn the AC on high. Are the fans spinning? They should be? ------------Yes
When the car is warmed up and you turn the heater on does it blow hot? ----------------Very little to none and no coolant leaks inside the car on the carpet?!
When was the last time you changed your radiator cap? ----------Yes recently
Posted at Sat Aug 01, 2009 9:22 pm
Hello –
Great info……….thank you very much for all of that.
Please do another check for me……….
Start the car and let it get to operating temperature…………
Once there, turn your heater on high…………..
Feel both heater hoses, the one going in and the one coming out………..
Are they both hot or is one hot and one cold………….
Posted at Sun Aug 02, 2009 5:37 pm
Hello –
Are they both hot or is one hot and one cold………Hot going in and Hot coming out, also the first time i have had any heat come out though i didnt test it while driving….
Posted at Mon Aug 03, 2009 8:17 pm
Hello –
Okay, thanks for that. Is the car still overheating at times since you now have heat in the car?
Posted at Wed Aug 05, 2009 3:39 am
Yes it still overheats, I did drive it on the freeway and turned on the heat full blast with the temp setting on hot as far as it would go and very little heat came out of the heater. Ok so now what? I'm really getting frustrated and i still havent had a chance to release the screw on top of the thermostat housing yet to try and release the possible aiir bubble, i will attempt that today. Thanks for you help.
Posted at Wed Aug 05, 2009 6:50 pm
Hello –
Thank you very much for the info……..
You are doing a great job on answering the questions………I appreciate that.
I understand it is frustrating……….they are…….sometimes it is easier if it just breaks all the way.
Why have you had to replace the heads 3 times…….because of overheating? Are they milled each time?
Me….it may be air…..the water pump or the radiator is clogged. From your symptoms are it is not circulating very good…….
Can you replace the housing that has the bleeder screw in it?
When did you change your water pump?
Have you ever had your radiator cleaned out? A new one at AZ is about 129.00 The radiator barn is about 100.00
How do you feel about back flushing your heater core??
Posted at Thu Aug 06, 2009 3:52 am
Why have you had to replace the heads 3 times…….because of overheating? YES Are they milled each time? AS FAR AS I KNOW THEY ARE HAD A MECH DO IT THIS TIME.
Can you replace the housing that has the bleeder screw in it? I WILL SEE IF ITS REPLACEABLE OR IF ITS PART OF THE HEADS
When did you change your water pump? ITS BEEN SEVERAL YEARS 4 OR 5
Have you ever had your radiator cleaned out? A new one at AZ is about 129.00 The radiator barn is about 100.00 YES, THE RADIATOR IS FAIRLY NEW, I HAD IT REPLACED ABOUT 2 YRS AGO, SON TOTALED THE CAR, FRONT END.
How do you feel about back flushing your heater core?? I WILL TRY ANYTHING, WHAT IS THAT EXACTLY?
Posted at Thu Aug 06, 2009 5:19 pm
Hello –
Wow……3 times just seems odd………..
Okay so it started overheating about a year after the first water pump change. Then a year or so after that the front end damage and new radiator…………am I kind of in the ball park?
Guess we can do one of two things…………….
If you go to AutoZone they have over on the isle where radiator caps are a Prestone radiator flush kit. It has a couple of 2 different size T fittings – you take one and put it in line with your heater hose. It is the one with a cap on it and you screw your water hose onto it.
Then it has another 90 degree hose that fits onto the radiator……….you turn the water on…start the car and let it run………you do that until the water is running clear out of the radiator………
Then you drain it all……..do the 50/50 mix.
This is a lot better flush since it circulates through your entire system……….
However…….I would like you to connect your water hose into the outlet hose of the heater core and then let the inlet hose just hang then crank the water to it and see what flows out.
Then reverse it and see if there is good flow. After that then do the above……..what we are trying to see here is if your heater core is partially blocked. If you get heat on and off then that is the indication that it is……….
Water pump is still an option for the overheating but the no heat in the car makes me wonder about the core………
What do you think……….worth the try?
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Home l Help l Privacy Policy l User Agreement l About Us l Computer Repair Question l Contact Us l Link to Us l We're Hiring l Affiliate Program
  Copyright © 1999 - 2009 2CarPros.com - Professional Mechanics Online
