Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1994 Dodge Shadow Engine Noises and Loss of Power
Posted at Tue Jul 28, 2009 3:18 am |
By
rwiz38t,
Likes to hang around! |
Give Feedback | Votes: 0 |
Noises problem
1994 Dodge Shadow 4 cyl Front Wheel Drive Automatic 105k miles
94 Dodge Shadow ES engine knocking clattering when it is cold the knock clatter is not bad but as the car warms up the knock clatter increase there is a noticeable loss of power. I have checked all the fluids they are fine, the car does not seem to overheat. I am at a loss for what it could be, any idea's would be great! |
Find a
car repair manual for your Dodge Shadow Repair Question.
Posted at Tue Jul 28, 2009 8:58 am |
By
Docfixit,
Certified 2CarPros Master Technician |
         (4926) Give Feedback | Votes: 79 |
Could be rod bearing, piston wrist pin or valve train. Have you opened hoood a listened to locate source? |
Find a
Posted at Wed Jul 29, 2009 4:49 am |
By
rwiz38t,
Yes it seems to be coming from under the valve cover, I initially thought that they were out of adjustment, but got confused when the problem increase as the car warmed up and I had the noticable loss of power. |
Find a
Posted at Wed Jul 29, 2009 5:35 am |
By
Docfixit,
Your engine was known for taking out cam tower bearing and lifter collapse. As temp goes up oil thins and metal expands causing valves not to open as far and loss of power. |
Find a
Posted at Fri Jul 31, 2009 2:04 am |
By
rwiz38t,
Probably not worth fixing, is this a hard fix or something I can do myself? (probably not) |
Find a
Posted at Fri Jul 31, 2009 5:28 am |
By
Docfixit,
The fix is another cylinder head a reman is cheaper way to go or salvage yard. Other fix pull head take to machine shop they can ckeck bearing to cam journals and either replace cam or use oversize cam. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
