Engine Cooling problem
1994 Dodge Caravan 6 cyl Front Wheel Drive Automatic 154386 miles
I have noticed that after the engine reaches operating temp, if i then shut off the engine, that some of the time coolant comes out of the overflow tube. The engine does not overheat,but does seem to run a little warmer than in the past. Now the "Check Engine" light comes on, but all fluid levels are normal and oil pressure & coolant temp appear normal. Has anybody experienced this? What should i look for?
