Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1994 Ford Escort Fuel C...
Auto Repair2001 Ford Taurus Over S...
Auto Repair1997 Nissan Truck Fuel ...
Auto Repair2000 Bmw 316 Loss Of Po...
Auto Repair2002 Gmc Safari Power W...
Auto Repair1998 Chevy Cavalier See...
Auto Repair2002 Dodge Ram Black Sm...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1994 Dodge Caravan 1994 Caravan - engine starts but will no
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sun Jul 06, 2008 1:12 pm
By Greenvan, New to the forum
Give Feedback | Votes: 0
Computer problem
1994 Dodge Caravan 6 cyl Two Wheel Drive Automatic 125000 miles
I have a 1994 Dodge Grand Caravan ES with a 3.8L engine, and it starts but will not run. The Caravan ran well for 100 mile trip, and then I went to work and parked it, came back eight hours later and tried to start the van, and it would turn over, but did not idle without constantly goosing the gas pedal up and down, the moment the gas pedal was released the engine would die. The Caravan went from running perfectly fine to not running at all on the same day, which leads me to suspect an electrical component has failed. I checked for codes with the on /off (three times) and all I get is a 55. I have an Auto Xray scanner and it shows no stored codes. I have unplugged the battery to reset the PCM and this did not fix it. I checked all relevant fuses ( 16 & 20 under dash, and all under hood) I have checked the coil pack (proper primary and secondary resistance), I have strong spark on all plugs (pulled plug and viewed spark), I have fuel (pulled the Schrader valve on the fuel rail and pumped fuel into a jar), I examined fuel for water or contaminants (none found), I bought a fuel pressure gage and checked with KOEO and get 46psi ( Service manual says 48psi spec, suspect gage a little off), fuel pressure with engine on stays at 46psi ( with vacuum to regulator removed) I've checked for any restrictions in the exhaust pipe (none found, even disconnected exhaust pipe before catalytic converter to see if that may have collapsed and restricted air follow - did not fix), checked the air cleaner, and also tried to start the car with the air cleaner tube off (still will not run). When I say that it will start but will not run, it's as if the timing is off or the engine is starving for fuel or air, it will even begin to backfire at the intake manifold, but it will not stay running, and is not anywhere near close to even idling. I spray starter fluid in air intake and start the engine and it does run smoothly very briefly (maybe 1-2 seconds) before it acts starved again. This should indicate good air flow and spark. It raises the question of why the fuel flow is not consistent. I checked the relays by 12V energizing them and checking continuity (ASD and fuel pump and they work properly, even rotated other relays to be sure). I even jumpered the ASD and fuel pump relay to put in energized state - no help. I suspect the PCM, which I have removed and looked at the connectors for corrosion or dirt (I cleaned them anyway). I disconnect sensors (AIS & evap canister) and the scanner picks up the new codes and I can clear them, so that part of the PCM seems to work. I do not know if the camshaft position sensor or the crankshaft position sensor could be a possibility. But I do not understand if the PCM checks those in the first five seconds of cranking. Is the PCM not energizing the fuel injectors? I am baffled what to do next, other than to go buy a PCM and put it in. What do you think?
Find diagnostic tools, replacement parts or locate a car repair manual for your Dodge Caravan Repair Question.
By Advertisment,
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
