1994 Chrysler Concorde Air Conditioning stops working when
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Air Conditioning problem
1994 Chrysler Concorde 6 cyl Front Wheel Drive 125,00 miles
The air conditioner works fine when outdoor temps are under 80 degrees (approx.) Once outdoor temps go over 80 degrees the air shuts down.
Thank you very much for taking the time to review this problem.
Find a car repair manual for your Chrysler Concorde Repair Question.
Need to know the line pressures when the ambient temp is above 80. Might have too much in the system and the pressures go too high when it is that hot out. Does the fan work whent he a/c is on (engine cooling fans)?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
