Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Cooling problem
1994 Chevy Corsica 6 cyl Front Wheel Drive Automatic 10,000 miles
1994 chevy corsica that leaks water from the firewall near the heater core hoses there a rubber elbow but no hose attachs to it.
i have replaced a heater core in my corsica about 9 months ago. the heater core has a plastic liner/tub hannging underneath it which collects moisture-leaks and does have a small elbow which passes thru the firewall to dump the water onto the ground. If you are leaking thru that elbow quite a lot chances are your core is bad. The oem core was a dim witted design it has two plastic tubes press fit onto the aluminum core in my case the core was fine but the plastic tube cracked in half causing a leak.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
