Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Cooling problem
1994 Chevy Caprice V8 Two Wheel Drive Automatic 136000 miles
My temperature gauge is not working it never moves I want to buy a coolant sensor but I dont know if it will fix the problem. And also one of my elctrical fan does not come on what are somethings I can do to fix this problem.
You can jump the fan from the fan connector to the battery to see if the fan is bad or a fuse/relay/fan switch is bad.
Many GM cars use seperate senders for the gauge temp and coolant temp to the ECM.
Either the sender is bad or the gauge in the dash. You should be able to ground the wire from the gauge sender (gauge should go full hot) which should isolate the problem between the sender and the IP gauge.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
