Engine Mechanical problem
1994 Buick Regal 6 cyl Two Wheel Drive Automatic 76000 miles
The car doesn't start 20% of the time. If it doesn't start on the first try it won't start again unless I wait about 15 minutes. I have never had the problem when the gas tank is full. The car runs fine once it is started.
Find a
repair manual for your Buick Regal Repair Question.
Posted at Mon Apr 21, 2008 4:22 am
By
Advertisment,
Find a
So it turns over but wont start sometimes. Have a fuel pressure test done on it. Some of those older GM's had a "pulse dampener" on the fuel pump that when bad will by-pass pressure, unless the pump is completey submerged in fuel. If fuel pressure is the problem, the new pump should have a piece of injection hose to take the dampeners place.
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
