Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Ford Ranger Auto L...
Auto Repair2001 Ford Explorer
Auto Repair2005 Chevy Express Abs ...
Auto Repair2004 Ford Explorer Tie Rod
Auto Repair2002 Ford Explorer
Auto Repair2008 Bmw 318 No Heating...
Auto Repair2001 Chevy Blazer Need ...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1994 BMW 740 Engine shake?
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Jul 01, 2008 10:06 pm
By eSLeZ9MzTX, Likes cars!
Give Feedback | Votes: 0
Shakes or Wobbles problem
1994 BMW 740 V8 Two Wheel Drive Automatic 136000 miles
I have had this recurring issue for a while now. It's been intermittant. Seems to happen much more often before the engine is warmed up. Anyway, sometimes when I start it up, the car will shake a bit. Idle is smooth. If I pop the hood and take a look, I can see a block vibrating a little bit. What's going on?
Find a car repair manual for your BMW 740 Repair Question.
Posted at Wed Jul 02, 2008 6:56 am
By Dr. Hagerty, Moderator
Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2Reputation: 403.2 (403) Give Feedback | Votes: 9
Is the check engine light on? Has the PCV plate ever been changed? Have you had the faults read out if there are any? There are several possibilities that may be in play here. First, the state of tune the engine is in, fresh spark plugs, no leaky valve covers (oil gets in the spark plug wells) Second, the maintenance history, have you pampered the car or ? Third, the intake manifold gaskets might require replacement (goes hand in hand with the PCV plate) as well as the valley pan. Could also be profile gaskets on the intake manifold or an intermittent coolant temp sender.
Posted at Wed Jul 02, 2008 8:42 am
CEL has never been on, in my 6 months (about 3-4000 miles) of my ownership. No idea about the PCV plate. Valve covers are seeping, I think. You can see stains below them etc. I haven't inspected my spark plugs. No history, however, when I got it, the cooling system was redone (new water pump, radiator). I've also had a new camshaft sensor installed and new motor mounts.
Although the CEL has never gone on, occasionally, on the dash, I get a check control warning. If I press for more info, it says something about the owners manual.
Posted at Wed Jul 02, 2008 9:05 am
I would set an appointment to remedy these issues and repost with the results. Keep in touch.
Posted at Wed Jul 02, 2008 2:52 pm
I've been delaying getting my ps pump replaced thus far, but I think i'ma get it taken care of now. But, before that, I think i'll do a tune up (replace spark plugs, fluids, oil/air/fuel filter(s), use electrical contact cleaner on my ignition coils, clear memory on ECU and clean my MAF.
Any other ideas?
Hopefully that'll help..if not, back to the shop!
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
