Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1986 Chevy Truck 1 Ton ...
Auto Repair1989 Honda Crx
Auto Repair2002 Chevy S-10
Auto Repair1995 Pontiac Grand Prix ...
Auto Repair2006 Chevy Silverado Tr...
Auto Repair2000 Chevy Camaro Engin...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1994 BMW 525 Engine Cranks, but will not turn over
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Thu Jul 03, 2008 9:37 am
By jhammer018, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1994 BMW 525 6 cyl Two Wheel Drive Manual 199000 miles
The car had been driving perfectly, and then today i parked it and went to work. came back out and tried to start it but it would not turn over. there were no signs of anything going wrong. the battery works fine. what could break so quickly that would stop the car from starting?
Find a car repair manual for your BMW 525 Repair Question.
By Advertisment,
Posted at Thu Jul 03, 2008 10:26 am
By Dr. Hagerty, Moderator
Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6Reputation: 377.6 (378) Give Feedback | Votes: 8
With the information provided(Thank you for trusting us to help you) there are too many things it could be to list here in any type of order, so lets start with what has been done, and I assume you have not done anything yet other than an attempt to start the car and a visual inspection. Three things are necessary in order for internal combustion gasoline fueled engines to run, fuel, spark and compression. I will eliminate compression because we know the car did run, that leaves fuel and spark which in this case go together. So here goes with a silly question, is there fuel in the tank? Next item to consider, is the fuel pump working and is there sufficient fuel pressure? If there is spark, then a bit of aerosol parts cleaner sprayed into the intake should make the car start if only temporarily. If this proves true then fuel is the only missing component, and we are closer to getting you back on the road. If not then there will be a need to go further and I request you send me a private message to coordinate this repair as I find having to type back and forth too slow and awkward.
Posted at Sat Jul 05, 2008 7:23 pm
it wont let me make a private message post until i have made 10 posts myself. but i did try the parts spray, and the car started for a few seconds. what now?
Posted at Sat Jul 05, 2008 8:10 pm
This seems like a fuel pump issue. Check the fuses and look at the legend inside fuse box cover to get the right one and check it's integrity. Replacement of the pump and filter might be required, they are next to the fuel tank under the car, first check for power at the fuel pump. If no power then the fuel pump relay is next thing to inspect/replace, it is in the E box under the hood to the rear of the shock tower. There are four Phillips screws holding the cover on. The two square plastic relays in the center of the box, about 1" by 1" are the main and fuel pump relays, it will be either orange or green, the white one is the main relay. Remove it and tap it on something several times and try it again. Let me know how this works out, I will be standing by.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
