Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair & Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Discount Auto Parts
Vehicle Repair Online Repair Manual
Vehicle Repair Car Maintenance
Vehicle Repair Car Safety Information
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Forum Topics
Auto Repair2000 Chevy Silverado Not...
Auto Repair1988 Ford Bronco Will No...
Auto Repair2001 Toyota Sienna Stuck...
Auto Repair94 Pontiac Grand Am 2.3 Q...
Auto Repair2004 Ford Expedition Con...
Auto Repair1997 Other Plymouth Model...
Auto Repair2001 Ford Windstar Shutt...
Auto Repair2003 Mitsubishi Montero
Auto Repair1999 Lincoln Continental ...
Auto Repair1996 Chrysler Town And Co...
Auto Repair1995 Chevy Tahoe O2 Sens...
Auto Repair1986 Other Isuzu Models I...
Auto Repair1999 Volkswagen Jetta Ra...
Auto Repair1998 Dodge Neon Overheating
Auto Repair1991 Other Mercedes Benz ...
Auto RepairMore Forum Topics...
Locate Auto Parts
Latest How-To Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Automotive Repair Forum
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1994 BMW 325 Random Stalling and dies instantly while still
Posted at Thu Apr 17, 2008 4:34 pm
By sjw2152, New to the forum
Give Feedback | Votes: 0
1994 BMW 325 6 cyl Two Wheel Drive Manual 170000 miles
My car usually drives well. But randomly it stalls w/ light showing real quick. Sometimes, the engine just dies without any stalling or hesitating while I am still driving i.e. 40m/h without speed changes. Most time, I have to wait to start again. It won't start right away. All the electrical functions still work, even if the engine goes off.
Here are some suspect things. My car has soft-top and got wet last winter due to overflows from top-container. So water overflowed into bottom of the car. At the same time, I found the main power cable and the power cable to computer were damaged. So my mechanic fixed popped section of the cables. Since that, the problems started happening. After I dried my car under sunlight w/blow drier, the problems were gone for a while. About 3 weeks ago, I saw check engine light on. The code said 1221, which was oxygen sensor. And this is a key thing: I was stupid. I sprayed carb cleaner through air mass meter. The check engine light was gone. Everything looked fine. Two days later it stalled and died randomly. Somebody said it would damage the sensor. I went to mechanics, and he said examined values of air mass meter was 8; values should be between 8 and 20. I have changed oxygen sensor. Still no light. Working good for 2 days. The problems popped up again.
I remember the symptoms have been very similar since first happening.
So, could you give me some answers, even clues what is going on my car? I really appreciate your time and advice.
Find a repair manual for your BMW 325 Repair Question.
Posted at Thu Apr 17, 2008 5:10 pm
By Dr. Hagerty, Moderator
Reputation: 102.7Reputation: 102.7Reputation: 102.7Reputation: 102.7Reputation: 102.7 (103) Give Feedback | Votes: 6
At that age and mileage, I would check fuel pressure and delivery. Fuel pumps fail and you might be at the point where replacement is warranted. Also replace the main and fuel pump relays at this time.
Posted at Thu Apr 17, 2008 6:21 pm
Thank you for your response. BTW could you tell me how to replace them? I have no idea where they are. If you can, can you link any useful websites or web-pages?? Thank you again.
Posted at Fri Apr 18, 2008 8:43 am
The fuel pump is inside the fuel tank and can be accessed by removing the rear seat base (it snaps into place) there are 2 panels, it's the one on the right side. As far as the main and fuel pump relays, they are adjacent to the fuse box which is under hood and is on the left side close to the fire wall. The relays are under a rectangular black plastic cover, there are three relays, two of them will be orange and one will be white (or green) The main relay has 5 prongs and the fuel pump relay will have 4. As far as a printed manual for your car,I highly recommend Bentley publications and they are available from Amazon.com or perhaps online, there is also Mitchell manuals available through the 2carpros website.
Posted at Sat Apr 19, 2008 8:52 pm
I found my relays and pump, etc. But can you tell me how to check they are actually bad? I think my ABS relays are bad, because I hear click from the ABS and feel vibration from brake pedal. Please tell me how to check the relays are bad.
Posted at Sun Apr 20, 2008 6:08 am
As a rule, I just replace them, checking them is difficult due to the intermittent nature of the failure. As to the ABS issue, seek out a local BMW technician to assist you with the brake issue, safety issues are best left to trained BMW knowledgeable professionals. Are the brakes worn out and do you have warped rotors?
Posted at Wed Apr 23, 2008 6:35 am
oaky I changed MAF and test-drove. I don't experience engine died. But my car stalled a little bit with instant check engine right? Do you think it is fuel filter or crankshaft sensor???
Posted at Wed Apr 23, 2008 6:07 pm
It seems as if you have your own agenda and are not a listening for my advice. As my dad says "Due to the numerous complaints about the free service, it has been discontinued"
Posted at Wed Apr 23, 2008 8:35 pm
oh i am sorry that I didnt mention a few things. I have checked relays and they were okay (according to general diagnosis). And I have changed MAF due to advice from my mechanic. So I was asking that I should spend more money to change other parts. I am sorry for bothering you. Your advice was awesome, and I have no doubt about your favors. Thank you very much.
Make a small donation! (We will make sure your question will be answered promptly)
Reply to topic
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins.Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
Computer Repair
