Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 12,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1994 Acura Legend bumper brake light and TCS light on
Posted at Mon Feb 01, 2010 3:10 pm |
By
shouamoua,
New 2Carpros Member |
Give Feedback | Votes: 0 |
NO, THE DASHBOARD LIGHT IT WOULD COME ON AND IT SAY BUMPER BRAKE LIGHT. I HAVE CHECK THE BRAKE SWITCH RUBBER STOPPER IT NOT IT ALL THE LIGHT ON THE BACK WORK FINE WHEN STEP ON THE BRAKE ALL THE LIGHT COME ON FINE IT JUST THE DASHBOARD LIGHT THAT COME ON.
fOR THE TCS LIGHT IT WILL ONLY COME ON WHEN I DRIVE ON FREEWAY AND COME TO A SLOW AND STOP THEN THE TCS LIGHT WILL COME ON. IF I TURN OF THE ENGINE AND TURN IT BACK ON THEN THE LIGHT WILL NOT COME ON UNLESS I DRIVE ON FREEWAY AND COME TO A SLOW STOP I HOPE THIS WILL HELP. |
| Find out more about your Acura Legend Repair Question: NEED MORE
TECHNICAL INFO? Car Repair
Manual - Questions by Topic -
First Things to Check - How to Car Repair - How Does it Work?
- Donate Here |
Posted at Tue Feb 02, 2010 7:30 am |
By
KHLow2008,
Certified 2CarPros Technician |
   (2183) Give Feedback | Votes: 101 |
I believe you are referring to the brakelight failure indicators.
When the brakelight failure indicator lights shows, it could be due to a fault in the brakelight failure sensor, incorrect bulb ratings or intermittently failing bulb circuits due to contaminations.
Start engine without depressing the brake pedal. If the brakelight failure does not indicate, depress the brake pedal and if the indicator comes on and all brake bulbs are working correctly, check the brake bulbs sockets for contaminations. If any brake bulb had been replaced prior to this occurring, recheck the bulb ratings.
For the TCS light to show, it could be related to the brake indicator lights showing.
Here are diagnostic procedures if the above does not resolve it.
DIAGNOSTIC SYSTEM
TCS Control Unit
1 . TCS control unit includes self-diagnostics. It will store up to 3 codes. Self-diagnostic system is functioning as long as engine is running. When a problem occurs, the TCS indicator light will come on and trouble code(s) will be stored. If the ignition is turned off and engine restarted, the TCS light will not come on (unless another problem is present).ny trouble codes will remain in memory.
2 . The most recent code will appear first. The oldest stored trouble code will appear last. If more than 3 trouble codes were detected by TCS control unit, they will be erased from the memory. Vehicle may have to be driven to obtain complete self-diagnostic results.
Retrieving Codes
1 . Turn ignition on, with engine off. Ensure TCS light comes on. Turn ignition off.
2. Locate 2-pin self-diagnostic connector at passenger-side toe board. Install a jumper wire between White and Black wires of self-diagnostic connector. Turn ignition on, but do not start engine. TCS light should start flashing any stored code(s). If TCS light stays on and trouble code(s) are not flashes, go to TCS LIGHT DOES NOT GO OFF under
DIAGNOSIS.
3. A long (1.2 second) flash indicates main digit of DTC, and short flash (0.3 second) indicates sub digit of DTC. For trouble code identification, see TCS TROUBLE CODE IDENTIFICATION table.
Clearing Codes
1 . Turn ignition off. Remove ABS fuse No. 2 from under-hood fuse panel for at least 3 seconds.
Code No.Malfunction
1-2 . TCS Control Unit
2 . Parking Brake Switch Circuit
2-1 . Steering Angle Sensor Circuit
2-3 . Lg Sensor Circuit
3-1 . PCM Circuits Controlling Fuel Injection System
3-2 . Engine RPM (NEP Signal) Circuit
3-4 . Incorrect Reference Voltage (VREF) Circuit
3-5 . Incorrect BARO Signal
3-6 . Incorrect TPS Signal
3-7 . Incorrect Traction Control Valve Sensor (TCS) Signal
4-1 . Incorrect Right Front Wheel Sensor Signal
4-2 . Incorrect Left Front Wheel Sensor Signal
4-4 . Incorrect Right Rear Wheel Sensor Signal
4-8 . Incorrect Left Rear Wheel Sensor Signal
4-9 . Incorrect Signals All Wheels
5-1 . Incorrect TCS Valve Assembly Or Fail-Safe Relay
5-2 . Incorrect TCS Valve Operation
5-3 . Incorrect Back-Up Voltage (VB)
6-1 . Incorrect PCM Circuit Signals
© 2008 Mitchell Repair Information Co., LLC. |
- Donate Here |
Make a small donation! (We will make
sure your question will be answered promptly)
