Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1995 Chevy S-10 Multifun...
Auto Repair1993 Chevy Lumina Stalling
Auto Repair1998 Buick Lesabre Fuel ...
Auto Repair2001 Ford Ranger
Auto Repair1997 Chevy Camaro Hesita...
Auto Repair2003 Renault Megane Fuel...
Auto Repair1984 Subaru Impreza Over...
Auto Repair1996 Ford F150 Electrica...
Auto Repair1996 Chevy Cavalier Star...
Auto Repair1992 Honda Accord My Car...
Auto Repair1993 Buick Lesabre Ignition
Auto Repair1994 Lincoln Town Car Fa...
Auto Repair1999 Pontiac Firebird Va...
Auto Repair1999 Plymouth Breeze Hea...
Auto Repair1990 Jeep Cherokee Windo...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1994 Acura Integra Won't Start
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sat Apr 05, 2008 4:34 pm
By grantfitz21@gmail.com, Likes cars!
Give Feedback | Votes: 0
Engine Mechanical problem
1994 Acura Integra 4 cyl Front Wheel Drive Automatic 153000 miles
One day, I went out to my car in the morning and it just would not start. I had it towed to a dealership and they told me it was the distributor and it would cost me roughly $350. I decided to purchase the distributor by myself and install it on my car. After installation, I tested each spark plug to make sure I was getting spark, which I was. So I figured my problem wasn't the spark anymore. I also smelled gas when the car was turning over, but figured I'd check the fuel rail for gas anyways. So i took the fuel rail off and removed the injectors. Sure enough, gas spilled out of it. What could be the problem if the engine turns over, I found gas in the fuel rail, and I have spark? I looked for a picture of the firing order for my distributor and am pretty sure i have the right one. Please help!
Find a repair manual for your Acura Integra Repair Question.
By Advertisment,
Posted at Sat Apr 05, 2008 5:05 pm
By mastertechtim, Tech level 9
Reputation: 245.4Reputation: 245.4Reputation: 245.4Reputation: 245.4Reputation: 245.4Reputation: 245.4Reputation: 245.4Reputation: 245.4Reputation: 245.4Reputation: 245.4Reputation: 245.4Reputation: 245.4 (245) Give Feedback | Votes: 16
spark plugs fouled? distributor not in right? did you check compression.
Posted at Sun Apr 06, 2008 9:15 am
All of the plugs are getting spark. I tried adjusting the distributor and it didn't work still. The distributor is keyed so that you cannot put it in wrong...Maybe something wrong with my timing or compression? What would I need to do in these instances to get it working again?
Posted at Sun Apr 06, 2008 2:58 pm
check compression. are you sure the spark plugs are not fouled?
Posted at Mon Apr 07, 2008 12:52 pm
By Bruce Hunt, Certified 2CarPros Master Technician
Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5Reputation: 407.5 (408) Give Feedback | Votes: 39
if you have spark and it is strong, right? Then you have either got the plugs on in the wrong order or you have another issue. i have seen the crankshaft position sensor allow spark but it is not is the proper order for the engine to fire. Does the engine sound like it wants to pop and start? Check the fire order again and make sure.
Posted at Tue Apr 08, 2008 5:03 pm
The car turns over and sounds like it wants to hit. I can hear and feel the tail pipe expelling little puts. Could it be that I just have too weak of a spark and need to change the plugs?
Posted at Wed Apr 09, 2008 9:10 am
i think you have the right firing order for the plugs but you do not have the #1 plug wire on the correct post of the distributor cap. I would say that you are one a quarter of a rotation off. Try moving the wires one terminal left or right and fire the engine.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
