Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Computer problem
1994 Acura Integra 4 cyl Front Wheel Drive Automatic
what do i need to do i have a warning light senvise maint on my dash bord that came out after i deconect my battery wat do i do to turn of the warning light?
Try with the key off holding the odometer reset button in and then turn the ignition to the on position without starting it. Continue to hold the reset button until the light goes out.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
