Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1989 Chevy Cavalier Car...
Auto Repair1996 Dodge Stratus Engi...
Auto Repair1996 Pontiac Transport ...
Auto Repair2001 Dodge Stratus Cyli...
Auto Repair2001 Dodge Dakota Rear ...
Auto Repair2004 Dodge Stratus Clue...
Auto Repair1993 Honda Civic Distri...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1994 Acura Integra OVERHEATING
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Oct 01, 2008 10:15 pm
By scarmona316, New to the forum
Give Feedback | Votes: 0
Engine Cooling problem
1994 Acura Integra 4 cyl Front Wheel Drive Manual 150000 miles
Hi there guys i have a 94 acura integra ls none v-teck with a b18 ingine that keeps overheating i replaced all the hoses upper and lower plus heater hoses too what i noticed is that my overflow container keeps overflowing i drain it and it runs ok for a few days then it starts overflowing agian i also have my cooling fan on all the time cause of a bad temp sensor can you guys help me out??
Find a car repair manual for your Acura Integra Repair Question.
Posted at Thu Oct 02, 2008 11:39 am
By KHLow2008, Moderator
Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7 (179) Give Feedback | Votes: 13
Hi scarmona316,
Reserve tank overflows means coolant is being pushed out from the radiator.
Either the radiator cap is faulty or you have a head gasket problem.
Posted at Wed Oct 08, 2008 12:02 pm
By shin_2max, Likes cars!
Hi I had that problem too on my 98 integra...like the he said it can be your head gasket...take your oil cap off to see if there is any water substance or is the oil still black or is it brown...then check the water coolant to see if there is oil present like if the water coolant show oil substance if there is then you have an bad gasket get that fix and there hould not be anyproblems.
Posted at Tue Nov 25, 2008 3:37 pm
By F4I_guy, Tech level 2
Get a cylinder leakdown test done. This is the only 100% accurate way of knowing if the headgasket has failed. Some quick home checks would be to check for oil in your coolant or vise versa. Or remove your rad cap with the engine running(make sure there is no pressure in the system and the car is cold first) If the coolant starts to bubbling and boil and/or if you see exhaust smoke coming out, chances are your headgasket has failed.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
