Engine Mechanical problem
1994 Acura Integra 4 cyl Two Wheel Drive Automatic 140000 miles
My car stall when driving. After series of diagnostics, I have reached the step to look at the distributor because of no sparks in spark plug. After removing the distributor cap, I crank the engine. The distributor rotor does not move. Do you think it is timing belt problem? BTW, the water pump belt runs. Thanks.
