Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1993 Volvo 940 4 cyl Two Wheel Drive Automatic 125000 miles
I have a 1993 volvo 940 wagon 4 cyl automatic. At times it will not start. Sometimes it will run perfectly but then on the next time out it may not start at all. Twice it has cut off while driving (while coasting at low speed.) The car is sparking properly and I can hear the fuel pump running when the ignition switch is turned on. A code check turned up an idling control sensor. What are the possible problems? Thanks for your help.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
