1993 Volvo 940 High Pitched Grinding Noise on the Engine
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Noises problem
1993 Volvo 940 4 cyl Four Wheel Drive Automatic 142000 miles
My engine makes a loud high pitched noise that changes with the RPM's. It almost sounds like a metal on metal grind. Could it be the Harmonic Balancer?
Remove all drive belts and run, if noise is gone it will be in an accessory drive item, if still there, i think you will have to get a mechanic to listen to it as you will need to hear it first hand to help locate it.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
